Results 1 to 5 of 5
    bluemagicx's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Fix for TPU case volume buttons
    Saw this over at Xda developers. Just get some duct tape and make 3 layers to fit inside the tpu case where the volume button recess is. It works great buttons are so easy to use now. Brilliant.
  2. #2
    DarkEye40's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Re: Fix for TPU case volume buttons
    Can you provide the link for this fix? I can't find it on Xda developers site.
  3. #3
    S.I.D. CrAzY's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I got so frustrated with the tpu case I ended up just cutting out the volume buttons on the case.
    You can't even tell I cut anything off the case, it looks like that's how it was supposed to be and I don't hate the case that much anymore.
  4. #4
    JayWill's Avatar
    Posts
    Global Posts
    2,636 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by S.I.D. CrAzY View Post
    Is the case still fitting tight? The reason the manufacturer didn't do a cut out for the volume rocker was that it would cause the case to loose it's tight fit and hold on the phone.
  5. #5
    2ndaccord's Avatar
    Posts
    Global Posts
    110 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I have a quick fix the volume buttons. If you take a razor and slice along the sides of the volume buttons it makes the buttons easy to press but keeps the case stock looking.
