Results 1 to 4 of 4
- 03-15-2012, 03:54 PM
Thread Author #1
ICS Rom External SD card Problem
Running Calkulins stock rooted FC07 with FC07 modem and [KERNEL/RECOVERY][ICS] Rogue *Stock FC07* all flashings went well no problems,day 4 and running very well and stable goog battery life, also flashed Tiffs theme ICS _ statusbar_dialer_settings_MMS_ for FC07 so far so good, exept ext. sd cannot be accesed or cannot download or move apps to it. T/B allows me to restore out of ext. card but apps wiend up in int. sd.
In folders app I can see ext.sd also in settings "manage apps" I cant move anything to ext.sd. Tried diff card, tried formating diff card still NG.
Any ideas anyone. Would appreciate some input, Thanks in advance....
Pp.
- 03-15-2012, 05:00 PM #2Thanked by:
- 03-15-2012, 05:14 PM
Thread Author #3
Re: ICS Rom External SD card Problem
Thanks anyway its good to know that guys like you are around to answer most of our noobie questions. You haven't forgotten your ROOT'S - Get it ROOT -- LOL --- anyway you know what I mean,
Thanks again, will post back after I find the solution.
Pp.
Thanked by: - 03-16-2012, 01:05 PM
Thread Author #4
Reply
