Results 1 to 11 of 11
- 10-30-2012, 03:03 PM
Thread Author #1
Is This Normal Battery Drain?
I'm on ParanoidAndroid 2.16 JellyBean
When I'm using my phone (a bit of web browsing and other things) I noticed my battery went down about 30% after only 30 minutes of use. Is that normal?
Obviously when it's not being used the battery is barely going down but I wanted to know if this is normal or if I should look into doing something about this. If so, what?
Thanks. - 10-30-2012, 03:41 PM #2
Re: Is This Normal Battery Drain?
I have no personal experience with JB ROMS, but after doing a lot of reading all the JB ROMS seem to have horrid battery life. One of the reasons I haven't flashed one yet.
- 10-30-2012, 11:07 PM #3
Yeah some people experience bad battery drain with the aosp based ROMs. I bet when that happens if you turn your screen off for a while your battery will actually go up a bit. That happens to me sometimes.
Sent from my SPH-D710 using Android Central Forums - 10-30-2012, 11:47 PM
Thread Author #4
So what is the best practice for maximizing battery life in this case?
- 10-31-2012, 02:14 AM #5
Edited for misunderstanding
- 10-31-2012, 02:21 AM #6
In that particular case its kind of hard to say. Just make sure that brightness is down. You could try some placebo scripts. I've been using all the pimp my ROM tweaks and have had good results. Then there is the under clock under volt option. I don't like to go that route myself. I always end up with a less than optimal experience. That's just me though.
Sent from my SPH-D710 using Android Central Forums - 10-31-2012, 04:02 PM
Thread Author #7
"pimp my ROM tweaks"?
- 10-31-2012, 05:46 PM #8
Search xda. Yes, pimp my ROM.
Sent from my SPH-D710 using Android Central Forums - 10-31-2012, 06:07 PM
Thread Author #9
Ok so which version do I download?
XHDPI, HDPI..? - 10-31-2012, 06:56 PM
Thread Author #10
ParnoidAndroid is an AOSP ROM?
- 10-31-2012, 10:33 PM #11
Sorry hdpi and yeah it is aosp based.
Horrid.battery life is this normal
By Horr1bleK1tten in forum T-Mobile HTC SensationReplies: 17Last Post: 05-15-2012, 06:01 AM -
Droid Charge Battery Life? Is this normal?
By jmg002 in forum Verizon Droid ChargeReplies: 9Last Post: 06-02-2011, 03:32 PM -
Is this normal
By bucc0303 in forum HTC EVO 4GReplies: 17Last Post: 09-02-2010, 07:47 PM -
Is this normal battery life ?
By OrderedtheEvo in forum HTC EVO 4GReplies: 33Last Post: 07-08-2010, 07:04 PM -
Advanced Task Killer Battery drain is this normal?
By cheebahawk1 in forum HTC EVO 4GReplies: 13Last Post: 06-06-2010, 06:54 PM
Reply
