Page 1 of 2 12 LastLast
Results 1 to 25 of 34
    Question Palm Pre Car Charger?
    Will the Palm Pre Car Charger work on the HTC Evo? Thank you.
  2. #2
    Default
    i was actually curious if the regular palm pre charger would work...
  3. #3
    Default
    Since both use the micro usb... the simplest answer is: YES.
  4. #4
    Default
    I had the Touchstone mounted in my car. I'll really miss that great charging solution.
  5. #5
    Default
    Yes, it will work just fine.
  6. #6
    Default
    this should under faq..
  7. #7
    ayman86's Avatar
    Posts
    Global Posts
    214 Global Posts
    Default
    i plan on using the palm pre car charger for my evo. ill know when i leave bestbuy with the evo charging in my car on my way to work!
  8. #8
    dolomatt's Avatar
    Posts
    Global Posts
    56 Global Posts
    Default
    Both the car and wall charger work fine. Charges just as fast as the pre did.
  9. #9
    Default
    There was a thread somewhere that said you should only use an official charger or some nonsense (:
    7:40 Friday I'll be plugged into my RocketFish "Palm Pre" charger.
    As mentioned all micro-usb chargers should work.
    Evo4G. Now with more Internet.
  10. #10
    Default
    ohh great! i still have my palm pre car charger because it works for my bb tour so it should work for the evo...I think
  11. #11
    npark's Avatar
    Posts
    Global Posts
    658 Global Posts
    Default
    Quote Originally Posted by heberman View Post
    i had the touchstone mounted in my car. I'll really miss that great charging solution.
    +1
  12. #12
    Default
    Just because the it plugs in and seems to work doesn't mean you should use it. Each charger has different volts and hz. You need to see if they match for what is recommended for the EVO. You should be able to see once you get the EVO to see if the volts and hz matchup with the Pre or any other device.
  13. #13
    Default
    It may work but I don't think I'm alone when I say I'm gonna baby the hell outta my EVO, and that includes using an official car charger made specifically for the EVO. But that's just me.
  14. #14
    npark's Avatar
    Posts
    Global Posts
    658 Global Posts
    Default
    Quote Originally Posted by dfine1966 View Post
    Wow, different volts and hertz, eh? Your explanation "hurts"! ;-)
    1) USB (and all of the devices the OP mentioned) all use 5 volt DC. This includes mini-usb, micro-usb, and standard usb a-b cables.
    2) Re-read what I just wrote. DC. That stands for direct current. Direct current means, hertz does not apply. Hertz refers to cycles between switching polarity on AC, or Alternating Current. 220v/50hz refers to 200 volts, 50 cycles a second the polarity switches from each wire. The same principle for 110/60hz. This is why your response hurts so bad, it doesn't apply to this scenario--DC has fixed polarity.
    Wall power adapters, car adapters, computer USB ports all pump out 5 volts and Direct Current power. 5volts is the standard for USB, and nobody differs from that standard--else why conform to a micro-usb connector if you require a different voltage? The only difference is amperage, 500 miliamps, 1500 miliamps (or 1.5 amps as noted by the OP). This was the issue posed by the OP, and noted by previous posters.
    Thanked by 6:
  15. #15
    dolomatt's Avatar
    Posts
    Global Posts
    56 Global Posts
    Default
    The specs are the same. They are both 1000 milliamps. All I have used is the palm chargers so far and no problems.
  16. #16
    tkanavy's Avatar
    Posts
    Global Posts
    42 Global Posts
    Thumbs up
    Quote Originally Posted by npark View Post
    Thanks, that was highly educational
  17. #17
    shacker2762's Avatar
    Posts
    Global Posts
    3 Global Posts
    Default
    Great to hear that my Pre's wall charger will work. Now I don't have to crawl under my desk at work and plug in the EVO's charger.
    Now, can anyone out there get my Palm Touchstone to charge the EVO? :-)
  18. #18
    Default
    Quote Originally Posted by shadowgod View Post
    that's cool, sounds like you have extra $ to throw around...i'll pm you my paypal email address.
  19. #19
    MannyZ28's Avatar
    Posts
    Global Posts
    4,325 Global Posts
    ROM
    Stock
    Default
    I have the 850 ma Sprint charger with the glowing yellow Sprint thingy. It kept up with my Pre doing Navigation with the screen on the whole time and actually charging the phone while doing so. If I can do the same with the Evo, then I'll be happy. If not, time for a bigger charger.
  20. #20
    Default
    Quote Originally Posted by kessomatthew View Post
    THanks. That is what I had hoped.
  21. #21
    Gelst's Avatar
    Posts
    Global Posts
    200 Global Posts
    Default
    Quote Originally Posted by MannyZ28 View Post
    Manny, have you run into any problems with your car charger yet ? like the ones you stated above ?
    I'm worried that the sprint car charger wont be able to keep up the EVO battery on a long road trip with Navigation and who knows what else running..
    Anyone tested that out yet ?
  22. #22
    Default
    Quote Originally Posted by Gelst View Post
    i just bought the new Sprint OEM car and wall chargers specifically listed for the HTC EVO 4G. i posted the links in the other thread. they work great. check the model numbers when you buy.
    IMO don't scrimp on chargers.
  23. #23
    pwnst_r's Avatar
    Posts
    Global Posts
    776 Global Posts
    Default
    Quote Originally Posted by richcracker View Post
    Yes because that accessory will cost him a week's worth of a paycheck thereby only allowing his kids one hot meal a day.
  24. #24
    Default
    Pre charger works. My car charger keeps up in regards to charging while using navigation over long distances.
  25. #25
    MannyZ28's Avatar
    Posts
    Global Posts
    4,325 Global Posts
    ROM
    Stock
    Default
    I use Navigation almost every day, and using it with the charger plugged in, it charges the phone rather quickly, even with Navi on. So no, no issues with the Sprint charger.
    Again, mine is 850 one that has the Sprint logo on the back and a yellow circle around it that lights up when you plug it in.
