antianalog
I have not experienced an Amzer bettery but reviews from other Amzer batteries on Amazon claim they do not offer what you might expect.
There were tests done that show that aftermarket batteries do not perform at the advertised capacities. Save your money.
I love that everyone takes the batteryboss tests at face value.
I'd be suspect of battery claims in the same original form factor. I did get a physically larger battery for my Pre (Mugen) and it definitely had double the battery life.
I'd accept that a physically larger battery would give more juice but would want to see thorough tests for aftermarket batteries same physical size as
original.
Why wouldn't we?
Since I work out of my car all day, I plan to buy the HyperMac Mini external battery to power my EVO.
I will be primarily running the 4G hotspot function to keep my iPad connected to the net.
The battery is rated 7200 mAh and will charge a iPhone 6X.
Apparently you will need a micro USB to USB cable to connect the EVO to the battery.
Anyone plan to do the same?
Website
HyperShop - The Official Online Store for HyperMac + HyperDrive
If you work out of your car all day, why not just use a car charger instead of spending $100 on this thing? Are you going to carry this around with you outside of your car or what? Educate me please b/c i'm confused, thanks!
Love it...Any thoughts on THIS battery?
I read that it might require an aftermarket battery door, but it should get you through the day with heavy/spotty 4G usage. It was also designed to match the EVO's color scheme.
