1. aznmode's Avatar
    So after a long while of having no screen protector I decided to put one on since it came with the purchase of my phantomskinz body armor. If you guys didn't know, you need to soak the protector in warm soapy water and then put the protector on the phone and use the included plastic card to squeeze out excess bubble and water. So after several attempts of squeezing the water out using the included card in the kit, I did not realize that that small amount of water had managed to sip inside the bottom of the phone and wet the water damage sticker inside. I just remembered that the water damage sticker on the EVO is at the bottom but after I had applied the protector. So it was too late to do anything about it.
    The best way to probably squeeze out the water is side ways. If you do it downwards water will get into the bottom of the phone. If you do it upwards, water will get into the speaker grill. So just a heads up. Now I'm SOL if I need any type of warranty on my phone. I've emailed Phantomskinz about this already. But they probably aren't gonna do anything about it and deem it user error. So be careful when applying screen protectors that require use of water.
    07-09-2010 03:00 PM
  2. DougB541#CB's Avatar
    Thats what i was wondering (don't own an Evo yet).
    I did a phantom skin on my Pre (love the skin btw) and it was tough keeping the water from vital spots.
    Here is a tip though....go to Sprint store and explain to them your situation and show the phone working fine but seeing if they can note your account regarding it.
    07-09-2010 03:44 PM
  3. chaosrecords's Avatar
    Same thing happened to me
    I just took the sticker off.
    Cant prove water damage if theres no water damage sticker.
    The one on the battery clearly isnt effected so I dont think youll have an issue
    07-09-2010 03:50 PM
  4. kellte2's Avatar
    Crack strategy, but OK. Either way, same thing happened to me. Dubious/highly questionable sticker placement by HTC/Sprint.
    07-09-2010 04:00 PM
  5. Gekko's Avatar
    IMO these screen protectors do more harm then good.
    the EVO scratch test video by "Roman" conclusively proves you don't need them anyway.
    07-09-2010 04:04 PM
  6. kellte2's Avatar
    Conclusively how? That test is fine, but people come here complaining of scratched screens all the time. Fact is: glass scratches. $20 dollar protection is better than buying a whole new glass screen.
    07-09-2010 04:06 PM
  7. EVO1Android's Avatar
    I have always been a little leary about using the protectors that require you to use water to apply it.
    07-09-2010 04:07 PM
  8. Gekko's Avatar
    do you put plastic over your furniture too? do you have a bra on your car?
    07-09-2010 04:08 PM
  9. DougB541#CB's Avatar
    Some people do...will you tell them its not worth it?
    Bottom line its worth it to people who like protecting investments...doesn't mean its every investment.
    07-09-2010 04:32 PM
  10. kinster02's Avatar
    There are always the type that don't require any water like Amzer. I used to have a bra on my car back in the days when it was popular but I found it did more damage then good. You take it off and that part of the car was slight faded.
    07-09-2010 05:04 PM
  11. KSmithInNY's Avatar
    Same discussion found HERE
    07-09-2010 05:37 PM
  12. aznmode's Avatar
    I do hope there is another indicator inside. My charging port doesn't work 100% and was thinking about getting a replacement. I got the phone through telesales.
    On another note, phantomskinz assumed I'm a dumb a$$ and didn't know how to install the screen protector. Anyhow I know they don't know any better so there's no point arguing with them since they can't really do anything about it.
    07-09-2010 06:11 PM
  13. aznmode's Avatar
    Someone in that thread used bleach to un-dye the indicator haha. Still looks pink. Might be worth a shot.
    07-09-2010 06:13 PM
  14. kellte2's Avatar
    What happened to you defending your "conclusively proven" claim?
    07-09-2010 06:36 PM
