Results 1 to 9 of 9
    Default Using a dremel to modify harder plastic case
    Has anyone done this or even considered it to modify the cases to fit with the extended batteries?
    Sent from my PC36100 using Tapatalk
    HTC EVO 4G (rooted) > HTC Evo 4G LTE
  2. #2
    Default
    Quote Originally Posted by digink View Post
    Yes,Actually if I had the proper dremel tool with the appropriate round blade attachment head for that clean cut I would have a customized innocase ll,or even better cutting the rear plastic piece on the innocase active,but yes I've thought of it.
    Default Re: Using a dremel to modify harder plastic case
    I might try it I'm thinking about ordering the seidio battery this Friday.
    If you don't mind me asking, how much did you pay for yours? Did you get it from Amazon?
    Thanks
  4. #4
    project.in.process's Avatar
    Posts
    ROM
    Bamf Paradigm
    Default
    Thanks
    i bought my 3500mAh from Amazon for $59.99 (retails @ 69.99 officially) and paid $10 for shipping.
    it's worth it. i can go 2 full days without charge--and using the phone in every way.
    i ordered a soft case (.01c on Amazon) & used a credit card template to cut out the back to accomodate the soft case--took me 5 minutes and it looks professional.
    ordered another Hard case ($7.99 Amazon) and am going to cut out the back with my dremel this weekend when it arrives on Friday.
    it's actually really easy--use a credit card/drivers license as the template. mark it with a paint pen, or use an exacto-knife to carve a groove on the cover and then something sharper to actually do the final cut.
    ordered
    Quote Originally Posted by project.in.process View Post
    ordered
    Awesome thanks, I think I'm going to pull the trigger on this battery. I do pretty good with the stock one but I'd love that piece of mind of not having to care.
  6. #6
    Default
    Only prob I'd see with modding a 2piece innocase type would be that you'd be cutting off the center piece section which has the tabs that connect and hold the 2halves together,so I'm thinking it might have to be an "innocase active"style?
  7. #7
    Doyer's Avatar
    Posts
    Global Posts
    75 Global Posts
    Default
    I've never used a dremel on an EVO case, but I've used one on different plastics with varying results. If the plastic is soft, it can heat up and you can cut through it like butter, but then the plastic get all gunked up in the bit and you can warp it. On harder plastics it's not as much of a problem, but it's harder to get smooth edges.
    In general, very minor mods are much easier (obviously), but plastic hardness could be an issue.
  8. #8
    Default
    Sorry to state the obvious,but its just Amazing how the "extended battery carry solutions" venue hasn't really been tapped into by seidio or any other Chinese aftermarket companies with basic silicone protective cases.Granted its easily been discovered how to modify jelly cases,but what about the average Joe who isn't too handy and is wayy too anal for a choppy job,and is more than willing to drop $15 for a nicely designed silicone or snap on case for his/her device.perfect time for a connection to someone in the fabrication industry.
  9. #9
    72guy's Avatar
    Posts
    Global Posts
    64 Global Posts
    Default
    Quote Originally Posted by maximus71771 View Post
    +1.
