Results 1 to 11 of 11
    Default Seidio Innocell slim extended battery
    Any one try this battery yet. 1600 mah and slim like the stocker. Sounds good but $50 is more than I would like. Might be worth it though depending on the hours it might add.
  2. #2
    Default
    I want to know too.
    Please post back if you find any information .
    And I've only heard good things about seidio, except for their prices haha
    But its supposed to be top notch build quality. And now you'll have an extra battery when that one dies.
    That actually sounds really nice. I can just throw my stock one in my backpack and I'm good to go.
    I usually get decent battery but I carry my USB cable to charge when I can on the computer
    Sent from my SPH-D700 using Tapatalk
    EPIC 4G
    ROM: QUANTUM 2.O
    KERNEL: STOCK
  3. #3
    Kevin Gossett's Avatar
    Retired Moderator
    Posts
    ROM
    GummyCharge 1.9.1
    Default
    I don't really know much about batteries and whatnot, but with the stock battery being a 1500 mAh and this one being 1600 mAh, is there really going to be that much of a difference?
    Default
    You are probably right but you can dream Seidio makes good cases but I have never used their battery's before.
    Default
    I read on XDA that someone called Seidio and they quoted a 10% increase...
  6. #6
    Default
    Nice. Thanks for posting back.
    Everyone keeps saying "wah there's no difference." The truth is you don't know til you try.
    For me I'm looking at the fact seidio is a quality company and say they have the best batteries made from quality equipment.
    And just having 2 batteries would be nice.
    And there's definitely no way I am going to get the extended battery case that requires more bulk. The phone is as thick as I'm permitting. I don't Even use a case because I don't want bulk so the super extended battery Is out of question.
    However I do want to try the seidio case to see how much bulk it adds compared to the one I got from radio shack when I first got my phone.
    EPIC 4G
    ROM: QUANTUM 2.O
    KERNEL: STOCK
  7. #7
    Default
    I got mine for 20% off with free shipping. I think they're running a promotion until the end of the month. Google the promo code. I think it's xmas20. I've had mine for a little over a week now. It's weird, somedays, it seems to make a huge difference and my battery lasts all day with heavy usage. Other days, it drains as quickly as before. I guess the true test is really watching it when its idle. Sorry, I don't know how useful this post was.
  8. #8
    mbuxx's Avatar
    Posts
    Global Posts
    123 Global Posts
    Default
    im not sure about the seidio 1600 but i got the mugen and have just finished the full 5-6 drains and full charges as recommended and see no difference. Im currently looking at the 2800 mah on ebay..it doesnt look too thick but ill let you know!
  9. #9
    Default
    I lost about 1% an hour last with no usage. My weather app updates once every 3 hours. My email is pushed from K-9. FB and twitter never update automatically. Wifi turned on. GPS turned off. Rooted with D02-Kernel-LV-1250 lag fix.
  10. #10
    Default
    So I bout the Seidio 3000mah battery and my phone discharges at the same rate as it did with the stock battery. I loose 4% per hour, any thoughts.
  11. #11
    mbuxx's Avatar
    Posts
    Global Posts
    123 Global Posts
    Default
    Quote Originally Posted by SB03GT View Post
    wow...that doesnt sound right. Have you done like 4 or 5 full discharge and full charges? .. still 4 percent an hour... seems kinda pointless to have that big hump on the back at that.
