1. archos's Avatar
    Hello!
    A little while ago, while my Google G2 was updating the battery died, interrupting the process.
    When I went to turn it on later, after having charged it, it would load the HTC screen and stay frozen there, unresponsive to button commands.
    I pulled the battery out, went to the HBoot screen and tried to Factory Reset, but it would freeze.
    Recently, I went to look for some ways to fix my phone and learned that you can update the system from the SD card. I found that I was able to access the recovery menu, so I downloaded an update package, put it onto my SD card labeling it as "update.zip" and I tried to apply the update, but it didn't work.
    When I go the recovery screen and run the update I get these errors:
    E: Can't mount /data/data/recovery/log
    E: Can't open /data/data/recover/log
    E:set_bootloader_message_block: emmc_read_data fail!
    -- Install /sdcard ...
    Finding update package...
    Opening update package...
    Verifying update package...
    E:signature verification failed
    Installation aborted.
    E: Can't mount /data/data/recovery/HTCFOTA/update_result.log
    E: Can't mount /data/data/recovery/OMADM/update_result.log
    I'm a bit out of my depth when it comes to fixing the phone, especially if it involves fixing the eMMC. Is there any way around this problem? Am I loading the update from SD card incorrectly?
    Any help would be greatly appreciated.
    02-08-2014 07:59 PM
  2. wizzrah's Avatar
    Hello!
    Are you running a custom recovery?
    02-08-2014 09:54 PM
  3. archos's Avatar
    wizzrah,
    From what I understand custom recovery works only if you've rooted your phone. Which I haven't done and unfortunately, since I can't get past the HTC start up screen, I don't know how I would be able to do that. Is there a way to root the phone for custom recovery through the HBoot screen?
    Thanks,
    Archos
    02-08-2014 10:14 PM
  4. wizzrah's Avatar
    wizzrah,
    Thanks,
    Archos
    Can you access fastboot in the bootloader menu?
    02-08-2014 10:16 PM
  5. archos's Avatar
    Yes, what should I do from there?
    02-08-2014 10:28 PM
  1. KitKat trouble with OTG and Bluetooth
    By Karl Kulp in forum Android 4.4 KitKat
    Last Post: 05-02-2014, 11:44 PM
  2. Replies: 2
    Last Post: 02-13-2014, 07:19 AM
  3. Replies: 13
    Last Post: 02-10-2014, 08:44 AM
  4. Need help with video calls between the Galaxy S Blaze and an iPhone
    By androidfan4000 in forum General Help and How To
    Last Post: 02-09-2014, 11:21 AM
  5. My Moto G is Stuck in Boot Loop
    By AlexBates in forum Moto G (2013)
    Last Post: 02-08-2014, 10:47 PM
