Results 1 to 2 of 2
    Default Bricked G2x: In serious need of help!!!!!!!!!!!!!!!!!!!
    I rooted my G2x and installed CM7, and during the update process it went to the normal LG screen and then to the LG screen with the blue strip behind it and it is stuck there. I need to return this phone, but I can't because it's rooted. Somebody please give me some solution. I attempted pretty much everything.
    Thanks.
  2. #2
    Default Re: Bricked G2x: In serious need of help!!!!!!!!!!!!!!!!!!!
    How did you flash CWM on your G2x? If you used Rom Manager, then that is your problem. Rom Manager fake flashes CWM. You need to use NVFlash to flash CWM and a recovery image. Read this thread over on xda: . Should do the trick.
