Can't unlock my G2X, need help
melga7
I bought a used rooted LG G2X, has ICS 4.0.2.. My son took it off the charger and tried to unlock it to play some games, and after like 5 tries it locked up and said I have to log into my google account to unlock the phone. I've tried this with the correct username and password (verified from my computer) but it will not connect. I do not have a data plan, just use Wifi to access the internet, and I alway keep the wifi off to save batteries. So now that its locked, I think it can't access the internet to unlock the phone from google because the wifi is off, and I can't get it back on. I decided that I probably need to do a system reset, and have been told to hold down the power and volume down button to reset, but when I do that, it says "software update" and nothing happens...
So I'm not sure what my next step is...Is there another way to do a system reset other than what I've been told? or another way to get the phone unlocked?
I'm a novice with this type of thing...
akbarramadhani12
