1. Jakub Vantroba's Avatar
    Hey guys,
    so there's this problem with my phone/MicroSD...
    I own a Huawei Ideos X3 and the card is 16GB Class 6 if it matters.
    Today the card simply stopped working I looked at my phone and none of the apps installed on the card opens,
    File Manager says there is no SD Card inserted, same when I go to Storage options, it simply doesn't recognize.
    As I put the card in nothing happens.
    I have connected the phone via USB to the comp but after I activate USB Mass Storage it only shows up internal memory.
    Another thing to notice is that the SD Card slot is overheating like a pig!
    I did let the phone cool up.. put out the Card and wait.. I also restarted the phone several times and let it off for half an hour.
    After putting the card back in again and starting the phone it went hot like hell after some minutes!
    Taking out the card and touching it did really hurt! It was that hot.
    I have music, movies, games and Audible on that phone,
    I can't do anything with that cheap Ideos X3, would be much easier having a Note 2!
    So guys I'm going to try the card on a friend's phone if it's the card's problem..
    If the card works, can I do anything else about it?
    And if it doesn't what can I do then?
    Is there ANYTHING I can do about it?
    Thanks for reading
    JackGrande
    06-09-2013 05:27 AM
  2. friedtators's Avatar
    it sounds like the phone is at fault. now is the card damaged? i would not trust the phone if its overheating and i would not put card back in phone. whats left? replace phone.
    Jakub Vantroba likes this.
    06-09-2013 09:00 AM
  3. Jakub Vantroba's Avatar
    Ok thank you.. I'm going to replace the phone.. again! It's the second time I replace it since I bought it in 02.2012.. goddamit!
    I'm never going to buy a Huawei again..
    Now I tryed the card in my friend's phone and it doesn't show up same as on my phone.. or another friend's phone tells with blinking "Damaged Card"...
    Both phones say that there's no card when I go to Settings-Storage
    I also tryed their cards in my phone but none of them doesn't even show up.
    What the **** should I do now?
    Also buy a new card? I bought this one in another country so no replacement possible..
    06-10-2013 07:06 AM
  1. sync with new upgrade doesn't work with outlook 2007
    By shin.andy in forum HTC EVO 4G
    Last Post: 06-12-2010, 09:56 AM
  2. Wireless N -- Doesn't work????
    By though in forum HTC EVO 4G
    Last Post: 06-05-2010, 03:08 PM
  3. Clock Widget doesn't work!?
    By krisrock in forum HTC Hero
    Last Post: 12-23-2009, 07:34 PM
  4. Google LISTEN (podcast) app doesn't work
    By EverythingiDont in forum Android Apps
    Last Post: 11-16-2009, 06:36 PM
  5. Google LISTEN (podcast) app doesn't work
    By EverythingiDont in forum Motorola Droid
    Last Post: 11-08-2009, 06:47 PM
