1. peweuk's Avatar
    I have had my phone for a few months and when I got it it worked fine.
    One day I noticed that the screen was unresponsive but only at the bottom (see red rectangle in image) - I rebooted and it was fine again.
    last week I noticed it was unresponsive at the bottom of the screen again, as well as the back and menu buttons stopped responding.
    A reboot got the back/menu buttons going again - but not the bottom of the screen.
    Today I find the back/menu buttons not longer respond again and rebooting does not restore the functionality.
    My question is - is this likely to be a screen problem or is it possibly a software issue?
    Any comments would be appreciated.
    02-15-2014 09:11 AM
  2. UJ95x's Avatar
    If you haven't dropped it or damaged it anyway it's probably a software issue.
    Have you tried factory resetting the phone?
    Sent from my Galaxy S4 running Slim Bean 4.3
    02-15-2014 09:19 AM
  3. peweuk's Avatar
    Thanks UJ.
    I have not dropped or damaged the phone, and have just done a factory reset which has rectified use of the back/menu buttons - but not the lack of response at the bottom of the screen
    02-15-2014 11:58 AM
  4. UJ95x's Avatar
    Thanks UJ.
    Sorry for the late reply. Just got back from a trip where I had no service
    I don't know what else you can try. Sounds like you need to get the screen replaced
    02-16-2014 12:48 AM
  5. peweuk's Avatar
    Thanks again UJ.
    I do not fully understand how the touch works on the screen and was not sure if it was possible for only a part of the screen to fail, and for such a uniform part at (ie a 5mm band across the full width so far from the bottom edge).
    I can get a replacement from china, but its 20 and I did not want to spend the money without being sure it would cure the problem
    02-16-2014 06:47 AM
  6. peweuk's Avatar
    Sorry - I meant to ask - is it likely to be the LCD or the digitizer (I can't find an LCD for the phone anywhere).
    02-16-2014 07:17 AM
  7. UJ95x's Avatar
    If it only happens occasionally it's probably the digitizer. I still think it would be cheaper to get it repaired than doing it yourself, at least based on what those parts go for here in the U.S.
    02-16-2014 02:27 PM
  1. Problem with transfer
    By FastNOC in forum Samsung Galaxy Note 3
    Last Post: 02-15-2014, 02:35 AM
  2. [GAME][FREE] Tri, A Game About Triangles
    By zztfox in forum Android Apps
    Last Post: 02-14-2014, 11:29 PM
  3. WIFI Grey to Green Question?
    By TheFinal UnchainedDemon in forum Moto G (2013)
    Last Post: 02-14-2014, 10:43 PM
  4. [Nexus 5] Question about different charger than supplied one
    By Deaglegame in forum Google Nexus 5
    Last Post: 02-14-2014, 07:15 PM
  5. question on free tethering
    By samkatz in forum Verizon
    Last Post: 02-14-2014, 05:53 PM
