Results 1 to 12 of 12
    Omer San Gabriel's Avatar
    Posts
    Global Posts
    379 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Battery damage?
    For example i own a phone at has input of 1,000mA then i plug it to a Power Bank that outputs 2,000mA. What will happen? Will battery be damaged?
  2. #2
    Sophia Zhao's Avatar
    Posts
    Global Posts
    99 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Re: Battery damage?
    nothing, the battery will not be damaged. But if conversed situation that the phone's input bigger than power bank's outputs, either the power bank or your battery will be damaged.
  3. #3
    mobilecrackers's Avatar
    Posts
    Global Posts
    538 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by Omer San Gabriel View Post
    Boom , it will hurt your battery as well as your phone. I had a experience.
    Press THANK YOU and LIKE button if you gets the answer
    Posts
    Global Posts
    379 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by Sophia Zhao View Post
    Quote Originally Posted by mobilecrackers View Post
    So how to know what is the max input of the phone?
  5. #5
    Posts
    Global Posts
    538 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Smartphones generally have chargers at supplies between 0.9a and 1.1a
    Amperage is the measure of how FAST electricity is moving in a circuit. Voltage is the measure of how MUCH electricity is moving in a circuit.
    Posts
    Global Posts
    379 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Currently using S4 and the charger outputs 2.0V. The charger is the one that comes with the package.
  7. #7
    Posts
    Global Posts
    538 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    This is ok . no need to worry they are official charges .
  8. #8
    dpham00's Avatar
    Posts
    Global Posts
    24,790 Global Posts
    Mentioned
    1 Post(s)
    Tagged
    0 Thread(s)
    2.0v is VERY BAD for usb charger.usb spec requires 5v. Now 2.0a is okay, and the s4 charger should be 5v,2a.
    dpham00, Android Central Moderator
    Sent from my Verizon Samsung Galaxy Note 3
    Posts
    Global Posts
    379 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by dpham00 View Post
    My bad. It's 2.0A
  10. Thread Author  Thread Author    #10
    Posts
    Global Posts
    379 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I'm planning to buy a power bank but i don't know what exactly to get.
    There is this one saying the Output is 5V - 2,100mA (max) and the other one is 5.3V - 2,000mA (max) both of them has 10,500mAh battery but i'm confused about their output. Please help.
  11. #11
    ardidito's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Oh so 2A is gonna destroy the battery unless the charger has an official packaging/logo.. now those 2A won't hurt.
    The fact is, smartphones 'of today' have current limiting abilities so that they only 'sip' from a 'stream' of electricity - whatever the manufacturer determined is the ideal rate. Now voltage.. overvoltage chargers will do damage because that's like turning the cup into a fountain and saying 'drink' as it covers you.
    Bad analogy?
  12. #12
    ardidito's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    See my response above for an explanation, but you want the 5V 2.1A charger. 5.3 is pushing is only a little, but better safe than sorry. Think of amperage as 'potential'. It won't keep pumping electricity into a device that doesn't want it, nor will it have to eat it, itself. If you have too low of wattage in any way, you run risk of burning the charger in one way or another.
  1. HTC One: android system draining battery
    By tashauphill in forum HTC One M7
    Last Post: 07-03-2015, 11:35 AM
  2. Don't believe the hype about good battery life.
    By 1812dave in forum Samsung Gear 2 & Gear 2 Neo
    Last Post: 07-31-2014, 07:40 PM
  3. Odd battery Observation
    By clitrenta in forum Samsung Galaxy Note 3
    Last Post: 05-13-2014, 11:31 PM
  4. Replies: 2
    Last Post: 05-13-2014, 07:48 PM
