Tablet with PoE and Ethernet connection
habrown
5
i'm looking for a way to use an Android tablet, and have an ethernet connection into it. i have used a PoE adapter with a nexus 7, but there is not an ability to use this with a network connection. I don't want to use the Wi-Fi as it won't work for the distances i'm looking to u across. it can be any Android tablet.
any ideas?!
The current commercial tablet pc is already very matured, tablet pc 7 inch up to 21.5 inch could be supported via 803.2 at / af, stay away from the consumer tablet pc plus POE adapter solution.
The most suitable size would be 7 inch, 10.1 inch and 11.6 inch.
pamatika
