1. someoneiusedtoknow's Avatar
    After i charge my phone to 100%, i can only use if for a few mins then it will restart itself and battery will just drop to 20% by itself, then it will just be restarting and restarting by itself, battery will be draining until i plug it into a charger
    06-13-2014 11:16 AM
  2. B. Diddy's Avatar
    Welcome to Android Central! What phone are you using? Does it have a removable battery? The behavior you're describing sounds like a failing battery. If possible, try a replacement battery.
    06-13-2014 12:50 PM
  1. Picasa, Google + & Phone Storage
    By tcm1969 in forum General Help and How To
    Last Post: 06-14-2014, 08:45 AM
  2. Bluetooth knocks out WIFI -- Kitkat issue
    By donnieco in forum Droid RAZR HD
    Last Post: 06-13-2014, 06:01 PM
  3. Replies: 0
    Last Post: 06-13-2014, 11:09 AM
  4. Android Central Forums Picture Issue
    By Almeuit in forum Android Central Apps
    Last Post: 06-13-2014, 09:55 AM
  5. call on phone AND bluetooth, is this possible?
    By jewelly in forum Samsung Galaxy S5
    Last Post: 06-13-2014, 08:25 AM
