I have the favorites widget with all of my friends on it. I want to remove a couple of people from the widget.
I know how to do this..you just edit the persons contact and "uncheck" them from your favorites list.
I do this, save the contact, and look at the contact and it says Groups : None.
I thought that would do the trick, but I go back to the widget and the person is still on the widget, it won't sync. I can add people i just can not delete people. Can anyone help? Thanks.
