- 07-06-2011, 11:27 PM
Thread Author #1
Sd card blank or has unsupported file system
Curious if anyone has seen this error. My sd card is not readable on any android phone or computer ive tried it on.
What I think broke it was the NEW SD CARD storage optimizer by Kalyani, I opened it up after downloading off the android market and used a feature called file explorer. It took forever to read all the files on my card and eventually I closed it out before its completion and immediately noticed my sd card is now inaccesable.
Is that error fixable or should I throw out the card? - 07-07-2011, 08:01 AM #2
Re: Sd card blank or has unsupported file system
Seems like the card got corrupt...there are programs for mac/pc that will try and recover the files from the sd card. Try searching for "sd card repair" or "retrieve files from sd card".
In all likely hood, you'll just have to reformat the card and it should be back up and running. Try formatting it from the phone or connect it to a computer and format it as a fat32 file system. Let us know how things go. - 01-15-2012, 10:59 PM #3
- 01-17-2012, 11:34 AM #4
Yes the card is probably corrupted and needs to be re-formated & checked for errors.
@ srkmagnus +1
SD Cards FYI:
Your SD Card should be Formatted on your device, ie phones, camera's, MP3 Players.
See if you can copy anything from the card to your PC,
Then format the card on your phone that it is going to be used on. Check directions for your phone cuz some usually require you unmount the card then format it while its in the phone.
There are special hidden files Android on the sd card that are used by the phone it was used on or formatted on, usually if you took a card from another phone & put it in your phone it will not work or your phone will be stuck in a reboot mode or be corrupted or just error.
Sometimes you can format your card on your PC to Fat32 sys file type and it will work but the rightway is to format the SDcard on your phone/device.
Hope that helps. - 01-17-2012, 11:42 AM #5
Also, be sure if you are connecting to a computer in disk drive mode that you always choose "Safely remove hardware" (or something like that) from the computer before disconnecting your phone. Not doing that is a sure way of corrupting your card.
- 01-19-2012, 09:16 PM #6
Have had this issue come up several times, for several months. Used to be able to fix it with a reformat of the card using SD's specific formater. Would have to save the contents of the card before hand on a hardrive folder. Then move back to the card after its formated in FAT32. No matter the card I use (I have used three of them) it always happens after a while. Somewhere a file keeps getting corrupted that cause the Android system to not recognise the sd card at all.
I have also reflashed new Roms to fix the problem. I think it is either Cyanogen, of gingerbread itself. It's got to be in the software codeing. I switched from CM7 to MIUI was working good for a while then boom, app crash...corrupt card. Very annoyed at android right now. Found the same issue on verizon forums using Motorola phones. I use a HTC Desire CDMA- Us Cellular.
From my research it seams to happen mostly with running an app off the SD card, or disconnecting usb cord. I have had it happen disconnecting from PS3 as well. Needs to be told to Cyanogen. - 01-20-2012, 01:52 PM #7
You should only be formatting your SD card with your phone. Sounds like you're not. And you encounter this problem after disconnecting the usb. Like I said in my previous post, if you're connected in disk drive mode, and your just pulling the usb, that is what's causing your problems.
- 01-27-2012, 08:58 PM #8
Nobody has addressed the OP's problem yet. He said the card was unreadable by his phone or his computer. How in the world can he do ANYTHING suggested here???
I have the same problem. I was using a sound recording app today and forgot to shut it off. Apparently it filled the MicroSD card. I eventually heard the notification that the SD card had a problem (I guess when it reached capacity) and started trying to recover it. Nothing recognizes it now. I ask that someone who actually understands the situation offer a solution. Thanks. - 01-28-2012, 12:32 PM #9
This has happened to me in the past, my phone was not reading my SD card. I took it to Verizon and they couldnt even figure out why it wasnt reading the card. They tried one of their cards and it still didnt work, so it was the phone itself. I had to get a totally new phone. Maybe thats whats wrong with yours.
- 01-28-2012, 01:01 PM #10
My Answer to the Original OP: Toss the card if non of what is listed already helps.
- Not familiar with OP's software, so that leaves many things, further the more information provided helps to diagnose issues
- Guessing & knowing are apples & oranges so we need all the facts always to try to help diagnose issues
FYI SD Cards: Corruption &/or defective sd card &/or phone hardware /software is a common issue
- There are a lot of cheap & fake sd cards out there. Try to buy name brand only in a Retail Pack, Not Bulk!
- SD Card failure is common in devices, not just phones, I said "Devices"; either from fake or cheap sd card, software issue (s), not 1st being formatted on the device 1st (its in most all phone manuals, buy hey, not many peops read them), not disconnecting from PC correctly, forcing, incorrect use, not handling with care, temperature, conditions, environment, Apps, rooting, Roms, doing things that they are not well aware of can damage, device / hardware issue and other
- Remove your SD card from your phone, insert it in a sd adapter, try connecting to PC, if the card reader is good (yes they go bad too) and is inserted correctly & fully see what your PC says. It may be able to read it, if so copy it to a new folder on your PC. If it says nothing or does not show, double check it, try another usb port, can also reboot your PC if you have not done so that day and try again. If it says its corrupted, try scan & repair in PC menu, may or may not work, if it does, when its done re-format the card to FAT32 file system, remove it correctly from PC, insert in Device & reformat on that Device. If it says the card is not recognized, try above.
If all that fails toss it & replace it. I would start off with only a New Retail Package 2gb card in case you have a device/hardware issue so it will save you some money if it kills that card. If it does kill the new card have your device checked by a pro.
I have had 4 phones that ate SD cards due to device hardware issues, but they usually do a FDR 1st and ask you try it with a new card. Yes thats how it usually works...
Also keep in mind the Micro SD cards are very delicate, u can break them very easily removing them & putting them back in without knowing it!
Forums like this are great tools, but not the one solution, sometimes you need to take your device to a hands on retail store tech (most are good) to have it checked properly "hands on".
So we are trying to help here
God Bless - 01-30-2012, 02:49 AM #11
The OP stated that his card was not accessible from the phone OR a computer. He (and I) hoped that there might be some other way, unknown to us, whereby it might be recovered. Everything your first post suggested ignored the part about it being inaccessible through normal methods. Thanks for your subsequent post which offered more information, however, the short answer to the question is this:
Once it has been determined that the card is readable by neither the phone nor a computer, you might as well purchase a new card. Yours is kaput. - 01-30-2012, 08:26 AM #12
- 01-30-2012, 04:38 PM #13
If you want to talk about time being wasted, your post did exactly that. Any random sampling from these pages will show you how stupid that sounds. When people have a problem and actually put some thought into describing it to help gain an answer, they aren't looking for guesses by people that either don't have a clue or that didn't bother to read (and comprehend) the problem, or a re-telling of the problem their Aunt Lucy had when she forgot her phone at the dentist's office.
This forum used to be a good source of useful information before there were millions of people out there with Android phones. It has now sunk well below the lowest common denominator. There is still some good help here, but it's not likely to come with the first asking. People that don't know what they're talking about should just be quiet and actually learn something. "What knowledge they have" says it all. - 02-03-2012, 08:20 PM #14
I'm on my third card/manufacturer. It's always the same, external SD apps get corrupted, Icons don't show up in Applications, but a copy is still on Settings-Manage Applications. Then in a couple of days the card cannot be read (with anything), I've seen all the errors including Unsupported file system. How or where it's formatted makes NO difference AFAICT.
It's interesting theory on the USB cord disconnect. But if if you just hit home when the Kies, etc... message comes up, I thought it only used USB for charging?
I haven't found a pattern, but something is corrupting the file system so it can't even be read on a PC. My suspect is HEAT. Hopefully somebody will find out whats causing this, I'm tired of reloading my music and SD apps?? - 10-02-2012, 10:27 AM #15
I have had the same problem. I realized that the problem was caused when I was taking pictures and the card capacity was reached. I was not able to delete anything of my card. I tried to format the card, but the same message "USB storage blank or has unsupported file system" has appeared. The card has not also run in any PCs as well.
Reply
