Purchasing A micro SD card for my Viewsonic G Tablet
Marlena
Need to know what "class" micro SD card is best for my Viewsonic G Tablet. I want to transfer some of my apps from my tablet to the card in order to have more space on the tablet. How does the class system play out, and what do I look for in the class and pricing? Thanks.
Typically, the higher class rating, the faster access times. In theory anyhow.
In camera's for example, where you typically only write foto data and view fotos, a class 4 will usually be ok, unless you have a high end DSLR, where you would probably want a class 10.
For a tablet, where you are more video/game oriented, I would suggest a class 10 card. And from a namebrand. Don't be lured by a lower class/no name brand. Yeah, you'll save a few bucks, but remember;
"Buy Cheap. Get Cheap"
Flykxd133
