EVO 4G Continually Trying to "Obtain ip address" at work
Doc
150
16
My EVO 4G will not connect to the WiFi at work now though it use to. I keep getting a message that it is trying to obtain ip address, which keeps recycling.
I have pulled the power to the router and have also removed the SSID from the phone and then re-entered the password (correctly). Nothing seems to change.
Those that have IPhones have no problem connecting.
Any suggestion that I can do on my end with the phone? I do not have access to the router to see if it is the latest firmware and I can not ask the powers that be to fix this since (this is not a thing that I need at work).
Thanks,
Doc
akbarramadhani12
