1. adambarrios1's Avatar
    I've read countless forums in search of answers but have yet to find anyone that has successfully rooted the Samsung Exhibit 4g. Is there anyone here that has figured this out or knows the likelihood? thanks
    nana_Neverson likes this.
    08-02-2011 03:34 PM
  2. pat23's Avatar
    Go get:
    Revolutionary - zergRush local root 2.2/2.3 [22-10: Samsung/SE update] - xda-developers
    then install it, then:
    adb push su /system/bin
    adb push su /system/xbin
    adb shell
    chmod 4755 /system/bin/su
    chmod 4755 /system/xbin/su
    exit
    adb install Superuser.apk
  3. Moscow Desire's Avatar
    Unfortunately, it seems there is no current simple method of rooting your device. However, as more people get this device, the dev's will find a way to root. Next will be the custom ROM.
    Just relax and wait
    08-03-2011 02:14 AM
  4. Terrigno's Avatar
    Have you tried SuperOneClick? If so, any luck with that? I know that application can pretty much Root nearly all Androids. Its what i use for my Infuse 4G.
    08-03-2011 05:47 AM
  5. Moscow Desire's Avatar
    current version of superOneClick won't work. There was a rumor that 1 person got it to work, but it wasn't true.
    08-03-2011 09:15 AM
  6. Ravenbrother's Avatar
    Is there a reason to root the exhibit? Unless you want a custom Rom it allows you to install software other than market. There is a setting to allow non market installs.
    08-30-2011 11:18 AM
  7. klauspabst's Avatar
    Many reasons!
    No bloatware,better programs, screenshots and so on plus the c7 rom !
    realy hope someone helps us with this phone to get a root!
    09-06-2011 02:12 AM
  8. igep's Avatar
    Is there any way to block ads without a phone being rooted? I have a Samsung Exhibit 4G.
    09-10-2011 11:17 AM
  9. Moscow Desire's Avatar
    Get the "paid" apps instead of the free ones, if possible.
    09-11-2011 02:38 AM
  10. pat23's Avatar
    It has been rooted
    10-23-2011 10:43 PM
  11. pat23's Avatar
    Go get:
    adb shell
    exit
    10-23-2011 10:44 PM
  12. andrebis's Avatar
    Fantastic! Worked perfectly. Got some weird errors about writing in the log but didn't seem to affect the end result.
    I also restarted my phone when it was done before I tried anything just for good measure. Don't know if it is needed - the error msgs made me a bit nervous though.
    Again, WORKS GREAT on Exhibit 4G - thanks again
    11-12-2011 03:12 PM
  13. brockolicious75's Avatar
    what really
    11-22-2011 08:19 PM
  14. xtc714's Avatar
    is there a custom rom for the samsung exhibit 4g ?
    11-26-2011 10:38 PM
  15. Blacsnake's Avatar
    Tried everything it says:
    * daemon not running. starting it now on port 5037 *
    * daemon started successfully *
    $ export TEMPRANDOM=95543;export PS1=END:$TEMPRANDOM;getprop ro.build.version.release
    2.3.5
    END:95543export PS1=""
    export TEMPRANDOM=77230;export PS1=END:$TEMPRANDOM;getprop ro.product.manufacturer
    samsung
    END:77230export PS1=""
    export TEMPRANDOM=94797;export PS1=END:$TEMPRANDOM;getprop ro.product.model
    SGH-T679
    END:94797export PS1=""
    export TEMPRANDOM=38510;export PS1=END:$TEMPRANDOM;getprop ro.build.version.incremental
    VKJ1
    END:38510export PS1=""
    export TEMPRANDOM=59142;export PS1=END:$TEMPRANDOM;ls -l /system/xbin/su
    /system/xbin/su: No such file or directory
    END:59142export PS1=""
    export TEMPRANDOM=33727;export PS1=END:$TEMPRANDOM;ls -l /system/bin/su
    /system/bin/su: No such file or directory
    END:33727export PS1=""
    export TEMPRANDOM=35300;export PS1=END:$TEMPRANDOM;chmod 755 /data/local/tmp/busybox
    END:35300export PS1=""
    export TEMPRANDOM=55707;export PS1=END:$TEMPRANDOM;rm /data/local/tmp/boomsh
    END:55707export PS1=""
    export TEMPRANDOM=87470;export PS1=END:$TEMPRANDOM;rm /data/local/tmp/sh
    END:87470export PS1=""
    export TEMPRANDOM=31633;export PS1=END:$TEMPRANDOM;chmod 700 /data/local/tmp/zergRush
    END:31633export PS1=""
    export TEMPRANDOM=62729;export PS1=END:$TEMPRANDOM;cd /data/local/tmp/
    END:62729export PS1=""
    export TEMPRANDOM=61534;export PS1=END:$TEMPRANDOM;./zergRush
    [**] Zerg rush - Android 2.2/2.3 local root
    [**] (C) 2011 Revolutionary. All rights reserved.
    [**] Parts of code from Gingerbreak, (C) 2010-2011 The Android Exploid Crew.
    [+] Found a GingerBread ! 0x00029118
    [+] Found a Samsung, running Samsung mode
    [*] Scooting ...
    [*] Sleeping a bit (~40s)...
    [*] Waking !
    [*] Sending 149 zerglings ...
    [*] Waking !
    [*] Sending 189 zerglings ...
    [+] Zerglings found a way to enter ! 0x18
    [+] Overseer found a path ! 0x0002b510
    [*] Waking !
    [+] Zerglings caused crash (good news): 0x40322cd4 0x0074
    [*] Researching Metabolic Boost ...
    [+] Speedlings on the go ! 0xafd25acd 0xafd3957f
    [*] Waking !
    [*] Sending 181 zerglings ...
    [+] Rush did it ! It's a GG, man !
    [+] Killing ADB and restarting as root... enjoy!
    but when I check it it says not rooted what is wrong here. Please HELP!!!!
    11-30-2011 01:51 AM
  16. jymmyblanka's Avatar
    You right my men, new version of Super one click 2.2 can do the work take like 10 minutes but do the magic you can get it here....forum.xda-developers.com/showthread.php?t=803682][APP]SuperOneClick v2.2 (now with zergRush and su 3.0) - xda-developers[/url] samsung exhibit 2.3.3 baseband VKE8 root it
    Thanks a lot """""CLShortFuse '''''''''''
    11-30-2011 11:25 AM
  17. EfreetDemon3's Avatar
    Go get:
    adb shell
    exit
    That's a terribly convoluted post, could you please re post it to make it more comprehensible?
    I've rooted phones before but i don't feel like bricking my wife's phone, I'd never hear the end of it :-P
    I'd like to put CM7 on it, it's a Tmobile exhibit 4G
    any advice help would be much appreciated
    11-30-2011 10:52 PM
  18. maheshhari's Avatar
    I think, there is a way available to root Samsung Exhibit 4G, and that's explained here:
    How To Root Samsung Exhibit II 4G
    Above tutorial uses the ZergRushMethod to root the smartphone and some users have confirmed that their Exhibit got rooted successfully using this method.
    12-14-2011 03:13 AM
  19. yachee's Avatar
    So I followed the directions at How To Root Samsung Exhibit II 4G - Tutorial | Android Lookout and now it says it's rooted and I have superuser installed, but how do I get all this bloatware off now? It still doesn't give me the option to uninstall. What are the steps to delete it all?
    01-22-2012 03:32 PM
  20. lion7718's Avatar
    Download 'Root Uninstaller' to uninstall, but I just use 'Bloat Freezer' to freeze them instead. Bloat Freezer pushes Ads now with Airpush on Wi-Fi only, but you can block those too.
    01-23-2012 06:27 PM
  21. cornonthecobtj's Avatar
    I have successfully rooted the Samsung Exhibit 4g !!! Its very easy and takes about 5 minutes using a program called oddly enough unlock root. You can get it at unlockroot.com. I learned about this root from . If anybody has any questions please feel free to ask.
    01-28-2012 05:42 AM
  22. tsureshraj49's Avatar
    Guys who want to see some Development in Samsung Exhibit 4G, please check this out
    xda-developers - View Single Post - Samsung Exhibit 4G
    03-09-2012 04:06 PM
  23. joseph_vn's Avatar
    This link show how to root Samsung Ex II not Samsung Ex I
    http://www.androidlookout.com/how-to...ibit-ii-4g/61/
    Are you sure it work perfectly for Ex I ?
    One more question! It look like that my fone was rooted. I was going around and accidently deleted some file. Now all things seem to be ok except the Android market. Everytime i run the Market. It hang for a while and then auto exit with error "Sorry! This application .........". It so fast i cant see what it say. I guest Market was broke.
    Can someone help me to fix?
    Thanks!
    05-14-2012 10:03 AM
  24. liyah3090's Avatar
    what did you do to root it
    09-24-2012 03:07 PM
  25. VFXAnomaly's Avatar
    I used this method, worked perfect for My New "Walmart" Samsung Exhibit 4g "Prepaid"
    http://androidforums.com/exhibit-4g-...ml#post5119406
    10-23-2012 10:22 PM
  26. Samarro Jackson's Avatar
    U can do screen shots on that phone anyway. but removing the bloatware is the best reason to root
    01-17-2014 05:21 PM
