1. carbaj12's Avatar
    my evo gives me this notification sd card blank or has unsupported filesystem, any way to fix this?
    08-09-2011 05:57 PM
  2. PvilleComp's Avatar
    Take it out and put it in your PC. See if you can read the data on it. If you can, copy everything off and then re-format the card as FAT32.
    If you can't read it on your PC then most likely the File system or the card itself is corrupt.
    If you can't reformat it - the card is shot.
    Hope this helps.
    08-09-2011 07:22 PM
