1. maperkins210's Avatar
    My Mytouch 4G was acting up last night so I pulled the battery and now it won't turn back on. It gets to the beginning screen then just keeps restarting to that screen. I plugged it in cause maybe it needed to charge but that did nothing. I left battery out for awhile but that didn't help either. Please help.
    08-14-2011 03:38 PM
  2. jggonzalez's Avatar
    I'm a newbie to Android, but I've heard there's a way to do a factory reset in situations like that. I think you try turning it on while holding the volume button down and it brings you to a menu with several options to recover. I've got a Sensation and had to do that. I had to reload everything, but I was able to recover. Its been about a month with no new problems. Try searching the MT4G forum for better instructions. Good luck!
    08-14-2011 06:18 PM
  3. Moscow Desire's Avatar
    Every phone has a slightly different method of "booting to recovery", however, they're pretty much using the same method.
    1. Turn upir phone off
    2. Holding the Vol +, turn phone on
    After a second or so, you can release
    You should be into the Recovery menu of your phone. From here, you can navigate using either the + - button, or the trackball (if you have).
    In the Recovery/Restore, you should find the factory reset option (wipe phone). Note that this will typically wipe all contacts and such, and should place it as a newly purchased phone, but the sd card remains intact.
    08-15-2011 03:31 AM
