DEAL OF THE DAY: Save 42% on the iBOLT Vehicle Charging Dock for Samsung Galaxy S3!
Results 1 to 3 of 3
    david7598's Avatar
    Posts
    Global Posts
    111 Global Posts
    ROM
    Stock Rooted JellyBean
    Default accounts and sync question
    Is there a difference between syncing Facebook and Facebook for HTC sense? Any reasons to sync both?
  2. Thread Author  Thread Author    #2
    david7598's Avatar
    Posts
    Global Posts
    111 Global Posts
    ROM
    Default Re: accounts and sync question
    Bump
  3. #3
    PvilleComp's Avatar
    Posts
    ROM
    CM-7
    Facebook for HTC Sense feeds the Friend Stream app/Widget. If you don't use it you can turn that one off and just use the Facebook app standalone.
    Some say that his dormant chips were left that way for YOUR SAFETY... Others say that once "turned on," he can not be turned off... All we know is... He's called The Stig.
