1. Mikethaler's Avatar
    We will be coming from BB land. All BB phones are designed to be used with a conforming charging pod that allows you to simply slip the phone in the pod (vertically) and charge the phone. Not only don't you have to bother constantly inserting the charger wire into the micro usb port, when in that position the phone displays the time in LARGE numerals. Great for on a nitestand.
    These items for a BB are less than $10 on Amazon. Didn't see any for other makes of phones, leading me to believe no other phone maker has this feature.
    A couple hours later. Did find a site that sells charging "docks" ("cradles", terms seem to be used interchangeably with "pod") for some Android phones.
    08-20-2011 10:42 PM
  2. Moscow Desire's Avatar
    I too had done some searching awhile back, and basically came up with little options.
    I suspect the problem lies with the mini-usb connection, where as the contacts are not exposed (allowing for easy contact to the cradle), thus making a cradle rather inconvienant. You'd probably have to "fiddle" with it before it would eventually plug in, thus increasing the chances of damaging the connector.
    But I also wish there was a cradle option.
    08-21-2011 12:53 AM
  3. NoSpin's Avatar
    I believe Tmobile makes cradles for the myTouch line, and samsung has a horizontal dock for several galaxy s variants on amazon.
    Wish more manufacturers would make it standard.
    Sent from my T-mobile G2 using Tapatalk
    08-21-2011 10:15 PM
  4. Moscow Desire's Avatar
    I found several at amazon.co.uk today.
    At least for some HTC models.
    08-22-2011 07:00 AM
  5. takeshi's Avatar
    It's not a problem in and of itself. There are certainly a number of Android device docks that connect via the microUSB connector. My Droid's desktop and car docks are like this.
    08-23-2011 03:28 PM
  6. NeilthePilot's Avatar
    A number of the Droids have charging docks. Most still use the usb connector. The Casio Commando has a separate set of contacts for its dock.
    08-25-2011 08:59 AM
  7. Moscow Desire's Avatar
    I think, it takes awhile for cradles, to catch up with the plethora of android phones emerging on the market every day.
    8 months ago, I couldn't find a cradle for my Desire, and now, tons of them.
    Casio??? They make watches and calculators....right? Please don't tell me they make phones also.....
    Joking of course
    Still waiting for a "docking station" similar to,,,uhgggg ipod/phone, which contains amplified speakers......
    08-25-2011 09:07 AM
