Results 1 to 4 of 4
- 09-02-2011, 07:24 AM
Thread Author #1
- 09-02-2011, 07:35 AM #2
Re: Samsung Galaxy Prevail (Boost Mobile)
Ok, so I assume the battery is charged? Silly question, but one has to ask. Check for a charging light.
Pull the battery, then re-insert it. Check for charging light. Leave plugged into a wall outlet.
Hold your Vol button (either + or -) then press power for a second or 2, then release both.
If it boots into recovery, then it's probably a software issue.
If the screen remains black, with a charged battery, then return the phone.
Could also be just a bad battery, but they can check that real quick at the Boost Mobile shop.
- 11-29-2011, 02:21 PM #3
I Miss with the samsung galaxy prevail and driod one the samsung prevail is a pretty good phone but i don't like that i can't get a recovery on iti have tryed clockwork recovery on rom manager DON"T it will crash your phone and all you get is a black screen it wont charge and it wont come back on eather i have crashed two phones for rommanager and i tryed rzr recovery crash it to so that sucks but anyways they don't just crash they still work good til you reboot and it will not come back on
- 01-03-2013, 09:46 PM #4
Reply
