What is the fastest 3G speed you can get on the speedtest.net app?
I got 2.2 mbs down an 0.7 mbs up on a Droid Incredible.
I managed 2500 kbps down with the Incredible.
2562 down, 1.3 up - Acer Iconia A501
2302 down, 1.4 up - HTC Desire
But really, this test is bogus as I doubt they are real scores. If you goto the app settings, and turn the animations to performance, you get considerably higher marks. What effect should the app animations have on DL and UL speeds????
Reminds me of the Quadrant app, and how easy it is to manipulate the outcome.
Are you on the newest radio?
