- 09-17-2011, 11:40 AM
Thread Author #1
Apps using battery
Hello i'm new here and have a question:
I have some apps who use allot of battery while i'm not even using them. For example i just started my phone, go to battery use and see a app is using 66%?? wtf, not all of them use so much. Most of them only 2-5 % which is too much for when im not using it. - 09-17-2011, 12:00 PM #2
Re: Apps using battery
Hold the phone chuck!
This doesn't mean that an app has used 66% of battery power. It only means that battery resources were directed to that app 66% for a given time compared to overall usage.
Like cell standby and phone idle. Usually these are higher than say Android OS, which is completely normal. It means resources were directed to phone idle 33 percent of the time. Not that it used 33% battery power. If you didn't touch your device all day, it would probably read 80% or higher.
Now if you have an app you don't use, like say Mail, and you see 20%. Then you can probably turn off notifications and synching, and it won't even show up.
I honestly wished they would do away with this Battery Stats menu. Or at least tell people how to interpret it.
They call it Usage. Not battery drain. It means a certain app uses battery a certain percentage of time compared to all other apps.
- 09-17-2011, 12:27 PM
Thread Author #3
- 09-17-2011, 12:38 PM #4
If you open the suspect app, and select Menu, you should see an "options" setting. Sometimes, they get sneaky and have a "More" selection, wherin you should find some sort of options for notifications, gps, etc.
This is one of the primary reason why people root and rom their devices. To get rid of thisuselessuhhmmm.... bonus feature software....
Oh, and if I helped you, hit the Thanks button. At 100 thanks, AC gives me a new device, and I'm damned close to that Galaxy S II
just jokingLast edited by Moscow Desire; 09-17-2011 at 12:44 PM.
- 09-17-2011, 12:55 PM #5
I agree with Moscow. You'll need to see what the settings are for the app to identify the problem. Sounds like something is keeping it awake.
- 09-17-2011, 01:01 PM
Thread Author #6
- 09-17-2011, 01:05 PM #7
Go ahead... Root.... come to the dark side....
Of course, it would help a little to know what device you have. Then we can guide you to the really dark side
- 09-17-2011, 01:14 PM
Thread Author #8
- 09-17-2011, 01:54 PM #9
- 09-17-2011, 02:16 PM
Thread Author #10
- 09-17-2011, 02:24 PM #11
Not with a root,
With a flashed rom, yes.
Of course, before rooting, you should back up your contacts and calendar. Google works ok. You can export your contacts to sd.
With apps,paid apps are always remembered by the market, so you can download again. Free apps, you'll need to remember. Of course there are apps that will bake them up to your sd,
Rooting, provided it goes as planned, should not show any difference, besides a superuser app in your programs.
- 09-17-2011, 03:07 PM
Thread Author #12
- 09-17-2011, 04:10 PM #13
Welcome to AC! Read the Xperia Play forum to understand root and how to do it.
Reply
