Results 1 to 3 of 3
    SEC
    SEC is offline
    SEC's Avatar
    Posts
    Default How do you delete Screen Capture application?
    Can anyone tell me how to delete the screen capture application on my Samsung Fascinate? I can force stop it or remove it from running applications but eventually it turns itself back on. It is beyond aggravating!
  2. #2
    DroidXcon's Avatar
    Posts
    Global Posts
    11,645 Global Posts
    Carrier
    Stock for now
    Default Re: How do you delete Screen Capture application?
    Quote Originally Posted by SEC View Post
    which application are you refering too?
  3. #3
    If you downloaded the app you go into the market and click on my apps scroll down and select the app click on it and then uninstall
    if it is an app you didn't get from market then you go into settings click on applications and then click manage applications your list will populate and scroll down to the app and then after you click on it you can click uninstall and it will remove it
    hope this is what you were asking
