I have a MyTouch 4G and the headset that came with it is fairly decent unless you want to run, then it is useless.
What I want is a headset with ear hooks of some kind, with the ability to control tracks and take phone calls. Regular earbuds just fall out when I get running.
Most of the headsets out there are iPhone compatible, which is no good for us Android users. The controls are incomplete and the microphone does not work.
There's gotta be a better version of the HTC set that came with the phone, that actually works with Android!!!
Thanks!!
Thanks!!
