HP TouchPad BlueTooth Wireless Keyboard
dna550
6
I am trying to use the HP TouchPad Bluetooth Wireless Keyboard on an HTC Incredible 2.3.4. I used as a guide this video:
Like others have mentioned here, I have been able to have Android recognize the HP TouchPad Wireless Keyboard, but when I try to use it to edit a Google Document, for example, I get the following message:
Android Failed to open a Connection to HP TouchPad Wireless Keyboard
I have used BlueInput as well as BlueKeyboard JP.
Teksoft - Future Teknology
https://market.android.com/details?id=elbrain.bluekeyboard.ime&hl=en
I should also mention that I have SwiftKey X installed on the droid inc.
https://market.android.com/details?id=com.touchtype.swiftkey&feature=search_result
Android allows me to choose BlueKeyboard JP or Blueinput, but neither application can make a connection with the HP Touchpad wirless keyboard.
What is disappointing, from an Android perspective, is that I was able to easily pair and connect the HP TouchPad BT Keyboard to an iPad 2. it was quick, easy and painless. In addition the keyboard works really well, no doubt because HP went to school on the Apple BT Keyboard.
Even if I could make this work on Android, using it would be a little klunky, nevertheless, I am still looking for a solution, because it would be very cool to be able to use this keyboard with the htc droid inc.
Well, I'm not a pro on pairing devices, but what I do know, is that some devices are not compatible with Android, when talking about pairing. It is not the same with all devices.
Bluetooth, is just a standard, a method. And as such, it can be adjusted to work only with specific devices.
One would like to think that "bluetooth is bluetooth", but unfortunately it is not. One can't pair a device with iPad, and think it will pair with an Acer A501 for example. Granted, it may be able to see the device, but to pair and become operational is different. It's not so much as a problem with Android, but more so with the manufacturer.
Best example to use, would be bluetooth earsets. Anyone who has ever used them, knows, certain ones do not work on certain devices. Because an earset will work on a nokia, doesn't mean it will work on an iPhone.
The best bet, is to make sure a device is Android compatible.If it specify's android versions, make sure it meets minimum requirements.
slackingfred
