Results 1 to 7 of 7
    cryandwriteasong's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Question Standby is killing my Samsung Galaxy Precedent's battery
    I recently got my first Android phone, a Samsung Galaxy Precedent, and although I'm impressed for the most part, I have had some issues in the four days I've had it.
    One of the main things I've noticed is that my battery is being drained like crazy. I took it off the charger at about 5am today, and it was at 100%, and now, just four hours later (and with next to no use--just some alarms, and I checked my Facebook for about five minutes, then killed the app), it's at 42%.
    According to the Battery Use log, the battery use for my phone for the past 3h 42m breaks down to:
    Cell standby 72%
    Phone idle 22%
    Display 5%
    Android system 3%
    I can't figure out why on Earth standby is eating up so much of my battery. At this rate, my phone will be dead within seven hours of non-use, and that just doesn't seem right to me at all.
    Does anyone have any insight as to why my phone's standby is such a battery hog, and what I can do to stop it?
  2. #2
    Moscow Desire's Avatar
    Troubleshooter
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    Jiffy Pop Roots 3.47.114
    Default Re: Standby is killing my Samsung Galaxy Precedent's battery
    ok, forget what you see in battery stats, What it says, is not what you think.
    What it means, is that for the time your device was running since last boot, was that cell stby used battery 72% of the time. NOT that cell stby used 72% of your battery power.
    Those damn stats (and I wish they would remove them), only mean what used power a certain percentage of the time it has been running since bootup. NOT how much battery power it used from the battery's total power.
    What it tells me, is that for 72% of the time, you didn;'t use your mobile for calls, so the radio was just ...waiting And that for 22% of the time, you did absolutely nothing except look at it (probably it was sleeping)
    5% display, meant it just basically sat there, all alone..... all day long..... poor Android, no love....
  3. #3
    srkmagnus's Avatar
    Posts
    Global Posts
    13,764 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    Stock 4.4 (KitKat)
    Check your notification settings for the Apps you use and make sure the frequency period that the app checks for updates is low, or infrequent. Do you get good coverage where you are at? Poor signal will keep the phone searching for a tower and kill the battery. Same goes for wifi. Make sure wifi is turned off when not in use and disable data of you really don't need it.
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    My reception is pretty crappy (on average 1-3 out of six bars).
    After a bit of reading up, I realized that that although I had already disabled my Wi-Fi and GPS, my 3G was probably still constantly searching for a signal and draining my battery even when I wasn't using my phone, so I installed DataSwitch so I could easily toggle my data on or off as needed with a single tap.
    Now that I keep my data disabled when I'm not using it, my battery lasts much, much longer. I'm usually around 60-70% after a full day off the charger with some calls and data use.
    I appreciate you both taking the time to read my post and leave replies! : )
  5. #5
    Andrew Ruffolo's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    Stock
    When I had the cell-standby problem on the Epic, you needed to toggle airplane mode on and off with every reboot to fix the cell standby issue. If it works and helps you out, you'll need to do that with every reboot. Its a CDMA issue... but I'm not familiar enough with the precedent to know if its cdma or GSM. Hope this helps
  6. #6
    Thatonedudeguy's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    So. Im on gingerbread 2.3 on my precedent. I use this as a mini tablet. How does one entirely disable the cell radio functionality?
  7. #7
    B. Diddy's Avatar
    Posts
    Global Posts
    78,049 Global Posts
    Mentioned
    6 Post(s)
    Tagged
    0 Thread(s)
    Welcome to Android Central! Turn on Airplane Mode. That will shut off all radios (cell, wifi, Bluetooth). From Airplane Mode, you can still turn Wifi and Bluetooth back on.
Tags for this Thread
