Results 1 to 5 of 5
    cjlosh's Avatar
    Posts
    ROM
    Syndicate Frozen 1.2
    Default micro sdCard
    Ok, Guys I have looked everywhere. I have a Samsung micro 16gb card. It has movies and music on it but I can't delete the files or format the card. I have tried to format it on the computer, epic 4g phone and my K1 tablet. I have used this card on epic 4g and K1 tablet. There is no switch to lock or unlock. Also it has folder called .android_secure but can't delete it.
    Anyone have any ideas??
  2. Thread Author  Thread Author    #2
    cjlosh's Avatar
    Posts
    ROM
    Default Re: micro sdCard
    anyone???
  3. #3
    gdbjr's Avatar
    Banned
    Posts
    Global Posts
    146 Global Posts
    ROM
    Stock
    How have you tried to format it on the computer? Was it still in the phone? If not do you have another device you can use like a SD card adapter and plug into your computer if it has a SD card slot.
    What error were you getting when trying to format the card?
  4. #4
    srkmagnus's Avatar
    Posts
    ROM
    Calkulin 2.7/Desperado
    That's odd that you can't format the card. I would suggest trying via the computer and see if that works. What happens if you try and delete the .android_secure file?
    Apps that are stored on the sd card are stored in this file. If you delete it and it returns its because you are still saving apps to the sd. Check all the app settings/locations to make sure everything is stored on the device.
  5. #5
    joelmic24's Avatar
    Banned
    Posts
    Global Posts
    49 Global Posts
    Some sd cards have a small switch on them that prevents deleting or formatting. Check to see if yours has one.
