backup help?
sharpspike39
3
I have some game apps that are saved on my one android phone and i was wondering does anyone know how i can back up my saved data on all of my gaming apps so i can move them to my android galaxy player thats coming out soon? im really far on my plants vs zombies game and i dont wanna start over lol
You need to root the device and use an application like titanium backup our my backup pro to save the application and its data to install on another device. This is the only way.
ah...i see :( is there a easy way to root it then?
What device are you using? Once you answer that go hit the forum section for that device and check the rooting and hacking section. There will be helpful guides/tutorials in there on how to root your device. Many devices are very simple and can achieve root quite easily. Then its just a matter of downloading either Titanium Backup or My Root Backup from the Market (both free versions, pro not necessary) and create your backups of your data. Then you can pull those backups off your device and place them onto your new device (once rooted) when the time comes.
slackingfred
