1. cubancigar2000's Avatar
    When I go to a group and want to email all of them with one click, I have to put a chk mk beside each person and there are many? Is there a way around this
    10-13-2011 07:46 AM
  2. chemnerd's Avatar
    Use Contacts GroupU (it's an application). It allows you to set up groups and then with a tap choose to email or send a text and more. May not be the perfect solution, but it works well.
    10-14-2011 03:25 AM
  3. cubancigar2000's Avatar
    Thats where I have my group, in the contacts but still have to chk mk each one?
    10-14-2011 05:08 AM
  4. Moscow Desire's Avatar
    The poster meant, it's an application (Contacts GroupU) you can download from the Market Not the stock contacts app.
    10-14-2011 05:35 AM
