Results 1 to 2 of 2
    Default sync calendar
    Looking for an app that will only sync's my dalendar from Outlook. Can nto find one. any ideas?
  2. #2
    Moscow Desire's Avatar
    Troubleshooter
    Posts
    ROM
    Jiffy Pop Roots 3.47.114
    Default Re: sync calendar
    "My Phone Explorer". Will sync to and from Outlook, whatever you select (except notes)
    Only downside, it requires a small client app on the PC, but it works well. And I believe it's still free.
    Never trust the cloud....
