DEAL OF THE DAY: Save 42% on the iBOLT Vehicle Charging Dock for Samsung Galaxy S3!
Results 1 to 2 of 2
    pspmaverick's Avatar
    Posts
    Global Posts
    2 Global Posts
    Default Issues with Browser
    I just had to call in to tech support with my carrier and if your getting a problem with your browser where the progress bar is flashing and wont load the page you have to clear your Data.
    These are the steps they had me go through to clear the Data
    Settings->Applications->Manage Applications->click on “All” at top of screen->go to Browser application->click “Clear Data”
  2. #2
    Default
    No you don't. Are you on verizon? Use the search widget, type anything, search, when the browser comes up, go to the settings and change your homepage from the verizon google page to just Google and it will work fine.
