New to Android, and loving it so far. Here's my (most recent) question:
Seems all my document files (word, excel, etc) initially copied from my PC to the microSD card are showing as read-only when I try to save them after editing.
I'm hoping this is some sort of screw-up on my part... did I do something wrong, or what can I do to correct?
Found two old possibly relevant threads, one not really. In the other, the person just cleared the cache (which cache?) and deleted a possible offending app.
Files were copied from PC to card while card was in the S2. Plugged the S2 into usb connection on PC and used explorer window to copy files.
Opened a Word document on my PC (file stored on SD on phone), edited it, and tried to save it. Word said file was read-only. Saved file to a temp location, used explorer to copy it over the old file.
Same scenario in Excel.
Also, if in Word or Excel, neither application sees the phone when trying to open a document (Using File, Open).
Explorer shows the device connected as: SPH-D710, with Card and Phone as sub-directories.
Is this normal/routine?
Any help/guideance is appreciated. Thanks in advance.
