Is there a way to set only the external sd card to mount with mass storage and not the internal so my apps still work while connected to my pc? Thanks in advance.
Your SD card is what connects to the pc when you select disk drive. Your internal storage never connects to the pc. Your apps that are not on the SD card should still work, but I have never tried this.
My Droid X2 mounts both actually. It mounts three things. One is some garbage Moto software, probably a partition on my internal storage. Second, it mounts my internal storage. And, third, it mounts my SD card. I'm glad it does. Makes for great file management.
I guess every device is different then. That's why it's a good reason to let people know what device you have when you're looking for help.
