1. the2ndflood's Avatar
    Using a PC, what is the best format settings for a memory card that I will be using with my EVO3D? I keep having memory card issues and maybe I'm formatting the cards incorrectly.
    Posted Using My Sprint HTC EVO3D Using Tapatalk -
    11-03-2011 10:57 PM
  2. Cyber Warrior's Avatar
    FAT32 would be the most compatible..
    the2ndflood likes this.
    11-04-2011 12:20 AM
  3. the2ndflood's Avatar
    Thanks for the advice! What about the Cluster file size though? Should I set it to the default, or should I format the card using a larger or smaller Cluster size? Which is better small or large Cluster sizes?
    11-04-2011 03:32 PM
