I'm running CM 7.1 and recently installed the ICS theme for CM7. Looks great, and to top it off, I installed the LauncherPro ICS theme as well. On top of it all, I installed the ICS analog clock widget from the store. All in all, turns out I have a phone that looks exactly like an ICS phone.
Only one problem I'm having...
When clicked, the clock widget opens the default alarm clock settings, and I use Xtreme Alarm Clock from the market. Is there any way to change the default action of a widget on press, or does that need to be done on the side of the app settings?
I know how to clear app defaults in the applications list, but is there any way to establish a new default?
In short, I want the ICS clock widget to open a custom app, not the default alarm clock.
Help? Thanks!
Help? Thanks!
