Results 1 to 25 of 47
- 05-19-2010, 07:54 AM
Thread Author #1
How-to: Sync music (and Podcasts and Movies) over wifi from iTunes
One of the advantages Apple has (and will have until Google decides to build a desktop syncing application) is the seamless syncing with iTunes. You can just plug the phone/iPod in and you are golden. So, what do we Android users do?
One of the coolest things about Android is that you can use an app like that will sync playlists from iTunes on your computer onto the phone, artwork and what not all included. TuneSync is only like $4 so it is a great deal IMO. Check out their website for more details, but I have been nothing but happy with it. The first sync (and any thereafter where you will be adding a large number of songs) takes a long time, but if you set it up right before bed and leave your computer on and your phone charging, you'll have no issues.
A guy actually tried to release something similar for the iPhone but got rejected by Apple so wireless sync is something you can rub into any iPhone user =P
Once I got this thing set up, I quickly discovered I needed more space for my music. So, I just ordered this great deal on a 16GB microSD card off Amazon. 16GB for $30!. Now I just need to figure out podcast syncing and ill be set =]
Works great on my Inc, and hopefully will for you guys too.
[Update 23May]
I got my 16GB card earlier this week, so even if you select the cheapo shipping you might get it really fast. Copied everything from my old card to my new one and everything is working great.
Also, TuneSync can even sync videos and podcasts if you want it to! Super useful!
[Update 14June]
The folder paths TuneSync creates are compatable with the new doubleTwist media playing app available in the market. I like the style of it over the stock player so I use it in conjunction with TuneSync for actually getting the files onto my device.
[Update 13 July]
Just so as to be clear, there are many iTunes syncing solutions for Android users. In addition to TuneSync and DoubleTwist, many users swear by iSyncr. Try them out and decide which is best for you! =]
Note: Any podcasts you have will not show up in the main "podcasts" section of the doubleTwist app. They are in playlists > podcasts.
[edit] changed title to better reflect functionality of TuneSyncLast edited by Kyle Gibb; 07-13-2010 at 04:15 PM.
crap -> Droid Incredible (4/29/10) -> HTC Thunderbolt (4/9/11) -> Samsung Galaxy Nexus (4/1/2012)
Samsung Galaxy Tab 10.1 32GB metallic grey (6/17/11)
My website/blog
And find me on:
Google +
Twitter @kyleNgibb
gdgt
AppBrain - 05-19-2010, 07:57 AM #2
I can't wait to try this out. Thanks for sharing.
- 05-19-2010, 12:37 PM #3
Sounds intriguing. And Apple killed it on their platform? Why?
- 05-19-2010, 01:21 PM #4
- 05-19-2010, 01:26 PM #5
How does it compare to Double Twist? if I got the name right
- 05-19-2010, 02:11 PM #6
Is there something better to do if I dont have a wifi Connection at my house? Im using a Verizon data card for what it is worth.
- 05-20-2010, 01:51 AM
Thread Author #7
cause Apple doesn't like people messing with "core functionality" even when that functionality is improved...
doubleTwist won't work over wifi, it requires you plug your phone into your computer (but is a great piece of software)
doubleTwist lol =Pcrap -> Droid Incredible (4/29/10) -> HTC Thunderbolt (4/9/11) -> Samsung Galaxy Nexus (4/1/2012)
My website/blog
And find me on:
Google +
Twitter @kyleNgibb
gdgt
AppBrain - 05-20-2010, 05:14 PM #8
$30 is a great deal for a 16GB card! Please let us know how the card works for you once you get it and use it. I get kind of nervous buying big cards since my last card purchase was a fake/clone that didn't work. It was a 16GB Sony Memory Stick, so I am sure this is a different case.
Thanks!
- 05-21-2010, 01:37 AM #9
- 05-23-2010, 10:45 AM #10
- 05-23-2010, 10:58 AM #11
I am confused.
Verizon Wireless specs the Dinc being able to handle up to 16GB, but every other review or spec I have read says it can handle up to 32GB.
Can anyone confirm this please? I would like to buy a card, and would rather get the 32GB if the Dinc can handle it.
Thanks! - 05-23-2010, 02:41 PM #12
It would be great if they had an app that synced everything ( contacts, mail, calendar, apps, video etc) , not just iTunes.
- 05-23-2010, 05:43 PM
Thread Author #13
It has worked great, when I got it I basically just coppied all the files from the 2GB to my new 16GB. Took a bit for all the music to re-import into the music app, but so far has worked great.
well, this is a feature coming in the future and is not in Froyo so the soonest it would come would probably be along with Gingerbread (2.3). So, if you want to sync your music before then, this is what you need =]
The initial transfer took longer then I would have liked, but you only have to do that once. A class 2 does 2MBps transfer rate which for most tasks is more than enough.
As for 32 GB cards, they can be used but your phone can't format them properly. Search on Google or the forums for advice to getting it to work.
Hehe. Well, I forgot to mention that TuneSync can sync any playlist in iTunes. And iTunes has playlists for podcasts, movies, and TV shows. You wont be able to use videos bought off iTunes (I think they have DRM) but if you rip a movie off a DVD you should be golden.
As for as contacts, mail, and calendar, you can just use the Google equivalents of all of those. The phone will sync with gamil and google calendar.
For apps, there are several services such as that will help you out until Google does the OTA app syncing.
Also, my card wasn't supposed to ship until the 25th. It got here on Tuesday =]. Go Amazon!crap -> Droid Incredible (4/29/10) -> HTC Thunderbolt (4/9/11) -> Samsung Galaxy Nexus (4/1/2012)
My website/blog
And find me on:
Google +
Twitter @kyleNgibb
gdgt
AppBrain - 05-23-2010, 07:22 PM #14
- 05-23-2010, 08:51 PM #15
- 05-23-2010, 08:53 PM #16
- 05-23-2010, 09:22 PM
Thread Author #17
My website/blog
And find me on:
Google +
Twitter @kyleNgibb
gdgt
AppBrain - 05-23-2010, 09:54 PM #18
- 05-23-2010, 11:12 PM
Thread Author #19
My website/blog
And find me on:
Google +
Twitter @kyleNgibb
gdgt
AppBrain - 05-24-2010, 07:25 AM #20
Yea I use all of those plus Spanning Sync, but it's kind of a hodge podge to get it all working (I have a Mac which doesn't sync 2 way with some things). It would be nice to have 1 desktop program for it all. I used Missing Sync for BB and even BB's Desktop Manager worked well before I switched to Android from my Storm. And as much as I like using the cloud, I still want and need to have my computer involved on many levels.
- 05-24-2010, 06:19 PM
Thread Author #21
What I would love to see Google do would be an itunes like program but using amazon for music and videos. You could even buy audiobooks (audible) and ebooks(kindle) from it. They can do the cloud stuff just as well but for the amount of content it would be managing it would prefer a desktop app.
- 05-24-2010, 09:22 PM #22
Just ordered my 16GB card from the link you provided. Thanks for the info! Just received my ZAGG Invisible Shield in the mail, now all I need to order is the Black Silicone case from VZW. I will have all accessories in hand before my Dinc arrives. (c:
- 05-25-2010, 02:43 PM
Thread Author #23
My website/blog
And find me on:
Google +
Twitter @kyleNgibb
gdgt
AppBrain - 05-31-2010, 10:13 AM #24
What the heck is a Dinc?
- 05-31-2010, 11:00 AM #25
I really wanted to like this app, but I've had limited success with it. I'm running the Mac based server and sometimes the client will lose it's connection to the server and can longer sync, even if I do a force sync. One time, rebooting my Incredible fixed the problem, but I've never been able to get that solution to work again. Even after rebooting my Mac & Incredible. Even though it requires a cable connection, ISyncr is on my list of next apps to try.
arw01: I'm assuming Dinc is a short way of saying Droid Incredible.
Reply
