1. utupelo's Avatar
    For about 2 days now the battery on my Droid 3 is draining alarmingly fast. Battery use indicator says that com.motorola.service.main is using 65% of the battery. I have Googled and searched the forums. Most of the answers come back "corporate sync" but I'm not on my exchange server at work. A few of the things I have done in the last few days:
    Downloaded and used .PodKast and subsequently uninstalled
    Added a gmail account and subsequently deleted it.
    Downloaded a live wallpaper called Koi Free and switched back to static wallpaper
    I'm not sure what updates have been performed.
    I just tried killing processes one at a time to see which one is killing the battery but got nowhere with it.
    Help. I'm a battery obsessive and I can't get any work done till I figure this out.
    11-07-2011 09:29 AM
  2. Devinator's Avatar
    I'm sure if you search the forums you can find some apps that will give you more specific battery detail. Like, which app is using battery. Maybe give that a search and see if you can find an app. Then once you have one, you should be able to find your culprit. If not, try searching google for battery usages apps.
    11-07-2011 11:35 AM
