Results 1 to 5 of 5
    will kennard's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Calendar Storage - Data Usage!
    Ok so I am from the UK and have just got an HTC Android phone. I have a data usage limit of 500 MB per month on my ty UK network.
    I got the My Data Manager app to track my data use and at the top every time (of mobile data not wifi obviously) is 'Calendar Storage'. It uses up stupid amounts of data every day.
    I have gone through all my accounts that are synced to my device (facebook,gmail,GMX,linkedin etc) and I have disabled the calendar sync for all of them that have the option available. Yet it still shows as using data every day on calendar storage.
    It is driving me insane!
    Thanks in advance.
  2. Thread Author  Thread Author    #2
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Re: Calendar Storage - Data Usage!
    Anyone???
  3. #3
    Blibble's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default
    Hi. Did you find an answer to this in the end? I have a theory, which I haven't fully tested - I think 'calendar storage' includes weather.
    I turned off weather sync for a day and calendar storage didn't use any data. Since I've turned it back on it's using some data but not as much as before, not sure why!
    Sent from my HTC Wildfire S A510e using Tapatalk
  4. #4
    UCofUE's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Hi all,
    I have the same problem also. Did you able to find any solve for this?
    Thanks,
  5. #5
    daeganr's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Today, all of a sudden, the Calendar Storage used 93 MB of data! I called HTC, and they were very unhelpful. The best he could come up with was "a glitch in the program".
    And I have The Weather Network, and it doesn't show usage as your theory suggests. I'd love to hear anyone else's thoughts or solutions
