1. eazid's Avatar
    Hello. I have an HTC incredible. Moved from blackberry. Is there any way to set the default for reminders in the calendar application to "none?"
    It gives you options as low as 5 min to as high as it doesn't matter to me. I mostly but entries in without the need for a reminder. So needless to say I don't want to be bothered with removing them.
    Nothing serious. But it would be great to not have to go and select the reminder and then select none.
    05-19-2010 06:33 PM
  2. discdoc's Avatar
    I have an HTC EVO and I would also like to set the reminder time to "none." It doesn't seem possible, unless I'm missing something.
    06-13-2010 07:00 PM
  3. ericwchgo's Avatar
    I'm wondering the same thing.
    06-23-2010 08:05 PM
  4. acosores's Avatar
    Me too!!!
    06-26-2010 07:13 AM
  5. jlewis's Avatar
    I have an EVO, and I would like the default reminder set to None. Anyone figure out a solution, yet?
    06-30-2010 07:50 AM
  6. BrianMichaelSteck's Avatar
    Sorry to add to the list of grievances, but I'd love to see this feature too. I simply had to turn off all alerts and notifications.
    Menu > Settings > Reminder Settings > Set alerts & notifications > Off
    Not a great solution, so I hope an update adds that feature.
    "Let's hear it for the droids" - Remix 80's tune by Deniece Williams
    08-04-2010 03:07 PM
