1. britty3's Avatar
    I am looking for a way that I can track a cell phone without having to install anything on the phone. I have tried installing all of those background softwares and turning on the google latitude but my kid always figures it out and turns it off. He is very tech savvy and always knows when I've installed something and how to turn it off or delete it. I need a way to locate him without any installation and I'm not about to pay for this. We go through verizon and I know that you can subscribe to something like this but its ridiculous to pay to keep track of my kid. I know my way around a phone but I'm by no means any sort of programmer. Any suggestions?
    11-20-2011 02:08 PM
  2. Prebody's Avatar
    Corded phone
    11-21-2011 01:47 AM
  3. Moscow Desire's Avatar
    the problem, is that you're probably going to have to find somebody who knows a little programming.
    I suppose, it one could modify the app so it runs continuously, then '#' parts in the code such as menu's so a user can,t change anything (and set a refresh so that the processes would always be restarting), then it would only leave rooting the device, installing as a system app, then removing the root. I guess he wouldn't be uninstalling it unless he roots the device.
    just a thought.
    But if he's as tech savy as you say, then there isn't much one can do about it.
    11-21-2011 03:59 AM
  4. EvilMonkey's Avatar
    Tell your kid if he turns it off or uninstalls it, he loses his phone privileges.
    My kid isn't old enough for a phone (getting there) but he has the similar rules with browser history on the computer. If he clears it, I'll assume he was up to no good and he loses internet privileges.
    11-21-2011 02:16 PM
  5. sherri's Avatar
    My daughter is in her second year of college. I installed Mobile Recovery (free from Verizon). Has saved her butt a few times! Even used it to wake her (by making it scream...)
    If he is that tech savvy though, even making this a system app would be deleted. I vote for the loss of phone privileges.
    Sent from my Droid using Tapatalk
    11-21-2011 02:22 PM
