Results 1 to 2 of 2
    rex450se's Avatar
    Posts
    Global Posts
    51 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default market.android.com issues
    I am having an issue with the market.android.com website. When I log in and go to the My Library tab and then the Apps tab it shows all of the apps that I have installed over the years. However, as I page through them it stops at L apps. Everything after L is missing. Is there a way to fix this? Does anyone else have this problem? Any help would be appreciated. Thanks
    Victor
  2. #2
    androidmaster1's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Re: market.android.com issues
    check to make sure that the website and you android phone are properly syncing. re-sync everything first from your android phone.
