I have a rooted Droid Razr and have been searching for a way to lock it into 4g-only to no avail. At work I get a decent 4g signal, but for some reason it keeps switching back and forth between 3g and 4g, which kills my battery life. I can save the battery by locking it into 1x or 3g-only using #*#*4636*#*#, but it's annoying to switch back into auto network select every time I want to look something up. So basically I'm curious if there is a way to lock it into 4g-only so that if it's not getting a 4g signal it just quits working. I don't want it to toggle back and forth between what it thinks is the best network choice at that time.
Thanks,
Bodie
Thanks,
Bodie
