"My Calendar" keeps getting reset to default
holyjoe722
15
My apologies if this has been hashed over and solved. I couldn't find it anywhere, here or on the web.
I have a rooted Samsung Replenish running Leaf 0.2
From day one when I got the phone (before I rooted it), and after rooting, the calendar keeps reverting it's default back to "My Calendar" I can go in and change the default to another one and it changes back. Sometimes it changes immediately, other times up to several days later. No rhyme or reason that I can figure out.
Also noticed that the notification sound for the calendars keeps going back to silent. Absolutely useless if you need it to alert you to something.
Has anybody figured out the secret to getting the settings to stick? Can "My Calendar" be deleted somehow so that it no longer can be the default?
kemberley1
