Results 1 to 3 of 3
    Default Transfer contacts and contents between iPhone and android phone
    Here I outline the ways that you can avail to transfer contacts easily and quickly to the new phone.
    The process of transferring the contacts may vary in accordance to the model and the OS of your
    handset. As mentioned, from iphone to android phone, or from android phone to iphone.
    Transfer contacts from iPhone to Android phone, there is a simple initial load. Login to gmail and export your contacts to contacts.vcf . Then email contacts.vcf to your carrier provided account (for example: name#pm.sprint.com # of @). Then open the attachment on iPhone and allow your iPhone to import all contacts. It's done.
    Another, if you want to move other contents like music, video or ebooks from your previous mobile
    phone like iPhone to the brand new Blackberry or android phone, can help you back up songs, videos, photos, playlists, podcasts, Folder Rule and more to any folder on your computer desktop directly with auto-scans your iPod, iPad or iPhone device when running. The details will then get transferred to your new phones from your computer. Besides, you can manage ipod/ipad/iphone contents together if you want.
    For users of Windows Mobile, such as Samsung or HTC, Microsoft's Device Center or ActiveSync applications can be used to copy the contacts to your computer through Outlook. For transfer of contacts from a Windows Phone to another, it can be easily done with help of Microsoft's . It's said the service will shut down, if so, it's really a pity if it really done for windows users.
    Use Mobical, an online service that is available free and is also compatible with mobile phones like Nokia, Motorola, Sony Ericsson etc. All you need to do is setup the application in your old phone and create a backup of contacts in the cloud. Then again setup Mobical in your new handset and enjoy automatic download of all the contacts from the old to the new one.
    If your mobile phone is internet enabled, then you can transfer mobile Phone Contacts via app online and it becomes much easier. You can transfer your contacts freely and will not even require the help of a computer, but have not for iphone yet.
  2. #2
    Default Re: Transfer contacts and contents between iPhone and android phone
    best way to do it if you haven't already done it, is to manually type in all your contacts in to your google account. that way, in the future whenever you get a new phone you can just sync it to your google account and automatically have your contacts. make sure to add them to your "my contacts" group in your google/gmail account.
    • How to
    • How to
  3. #3
    jeanwendy's Avatar
    Posts
    Global Posts
    6 Global Posts
    Follow below to help you :
    Contacts - find some way to migrate your contacts too gmail or google contacts. Just sign in to your google account.
